K20 vs H22
Old Feb 16, 2008 | 04:59 PM
19Accord97
Default K20 vs H22
I am just curious, and not 100% I am remembering correctly, but I once saw motor mounts for the 5th gen Accords for the k20 engine (im pretty sure). Now they are not listed on there anymore
Anyways, I am just curious how the two would compare. If the K20 would need more tuning or what. I am sure it would eat the H22. And is the K20 better for turboing, since the h22 has weak sleeves?
Old Feb 16, 2008 | 05:00 PM
19Accord97
Default RE: K20 vs H22
http://cgi.ebay.com/ebaymotors/HASPO...spagenameZWD1VFound it!
If I had tons of money I would do this instead of an H22.
Old Feb 16, 2008 | 05:39 PM
yes hasport makes mounts for the k20 into the 5th gen accord.
the k20 is FAR better for turboing than the h22, it is also a really good all motor application. however you are going to spend way more money swapping a k20 in than a h22
seeing the motor itself is more expensive, the mounts are like $700, there is way more custom work that has to go into it.
Old Feb 18, 2008 | 12:13 AM
19Accord97
What all custom things have to be done? Mainly mechanical, or technical like wiring/OBD stuff?
Old Feb 18, 2008 | 06:04 AM
ORIGINAL: 19Accord97
i'm not sure as there isnt alot known about it because its not all too popular, i would imagine a fair amount of mechanical stuff, and alot of wiring.
Old Feb 18, 2008 | 11:05 AM
falkore24's Avatar
The K20 spins the opposite way which means that you have to swap the whole engine bay left to right.
Old Feb 18, 2008 | 11:19 AM
BlkCurrantKord's Avatar
ORIGINAL: falkore24
I hope your kidding.
Old Feb 19, 2008 | 01:23 PM
falkore24's Avatar
Well, if you want to just swap the engine and not the tranny.
Old Feb 20, 2008 | 07:14 AM
It still doesn't involve what you described.
Old Feb 20, 2008 | 08:52 AM
falkore24's Avatar
CRX with a B16
CRX with a K20
Prelude with an H22
