MAJOR PROBLEM!!!
Old Oct 22, 2006 | 01:23 PM
00_Accord_V
Default MAJOR PROBLEM!!!
Sup ppl, I hav a serious problem (i think) wit my accord. It was running fine until the other day as I was drivin down a steep hill my ABS light went on and then for some reason my RPM's and MPH seem to just drop to zero when im cruising and then go back up to the normal RPMs and MPH. It just cuts out for a second then its normal. This keeps occuring as I keep stopping at lights untill i got home and parked my car. The next day when i started it, everything was fine...The ABS light was off and the car ran normally but as I was driving back home, the ABS light went on again and the same problem occured again. I was wondering if anyone had a similar problem or know the cause of this problem. I drive a 2000 Accord V-tec 4 cylin.
Thx ppl
Old Oct 22, 2006 | 04:01 PM
Slusher's Avatar
Default RE: MAJOR PROBLEM!!!
Sounds electrical so start simple and check all your ground wires and battery terminal connections/cleanliness.
Old Oct 22, 2006 | 05:02 PM
00_Accord_V
The negative terminal does seem to get a lil corrosion but i just cleaned it. I havent checked the ground wires yet but i will. I was thinking about driving the car around until i get the same problem and then take it to Autozone to have the code read so I know whats going on....
ihonda
Aug 30, 2012 07:28 PM
brendenwestbrook247
Aug 8, 2011 06:41 PM
cjdm98
Aug 24, 2008 04:02 PM
neal916
Jun 13, 2008 01:20 AM
HONDAGUY1990
Sep 11, 2007 08:36 AM
