More Problems after Time Belt Change and etc..
Old Mar 27, 2007 | 09:44 PM
  #21
sir_nasty's Avatar
Default RE: More Problems after Time Belt Change and etc..
It sounds like a bad heater core.... without going back and re-reading the notes was that mentioned or checked already?
Old Mar 27, 2007 | 11:38 PM
  #22
RoKnAzn's Avatar
I believe so too...I pulled the carpet on the passanger side and it was soaking wet. I also touch the tunnel and it was wet. So I think that is it. I just called Advance Auto Parts and order one for 57 Bucks from Rad-Flow. How hard is it to remove the Heater Core?
Thanks
Anthony
Old Mar 28, 2007 | 01:19 AM
  #23
deserthonda's Avatar
ORIGINAL: RoKnAzn
I. How hard is it to remove the Heater Core?
Thanks
Anthony
before you replace the heater core make EXTRA sure that is what is leaking ,, cause,, it is NOT an easy job to replace it ,, the complete dash has to come off ,, I would suggest you buy an HELM book if you plan on doing it yourself ,, or download an online manual with all the details ..
Old Mar 28, 2007 | 01:25 AM
  #24
RoKnAzn's Avatar
ORIGINAL: deserthonda
ORIGINAL: RoKnAzn
Thanks
Anthony
That is the only thing that can leak inside the Honda unless Im mistaking.. I have the Haynes Manual and it looks pretty simple. Just wanted to be prepare for the removal and install..
Thanks
Anthony
BTW. Where can I download the Online Manual?
Old Mar 28, 2007 | 02:35 AM
  #25
Heater corewould bethe only place for antifreeze to come from, & get under the carpeting. Are you sure it's antifreeze? By the smell?
It seems to me that if the heater core were leaking, it would fog up the windows something fierce.
Like desert says, it's a big job. Make sure that's really the problem.
Old Mar 28, 2007 | 12:30 PM
  #26
RoKnAzn's Avatar
ORIGINAL: JimBlake
Well, Before I start putting water instead. I have a Blue Spots on the carpet. So yes, 95% sure of it. I always drive with the windows down. Plus A/c dont work no more (need to fix)..
jthanastyone
Dec 3, 2013 09:34 AM
Cateastrophe
Feb 8, 2013 06:56 AM
charlesnaija
Oct 6, 2012 09:05 AM
KincaidChance
May 3, 2011 01:13 AM
YeuEmMaiMai
Oct 17, 2006 04:32 AM
