Need Distributer Help.
Old Sep 30, 2006 | 08:08 PM
g1teg's Avatar
Default RE: Need Distributer Help.
Im looking at 16-82 now(fuel injected one) And i dont see a seal or stator listed. The carbuerated one lists those parts however. I dont know if you accidentally looked at the wrong page, or if you didnt know, mine is a FI model.
and i know its hard to diagnose something like this, Im sorry! haha i just was hoping someone would have experienced it before.
can you lend any thoughts on whether it would hurt my car to drive like this? should i pull my valve cover to make sure it isnt in there? I think the rubbing rotor/dust cover might be unrelated?
Jeff
Old Sep 30, 2006 | 08:17 PM
sir_nasty's Avatar
if you want to check for the noise location take a piece of a wooden broomstick handle (or something similar) and put it on the distributor and the other end on your ear, then try it on the valve cover and you'll be able to tell where most of the noise is coming from.... If you look in the lower left hand corner you'll see the o-ring that I was refering too.... no stator though... sorry didn't realize it was the FI model....
Old Sep 30, 2006 | 08:19 PM
sir_nasty's Avatar
I think I found something.... Desert Could have probably cited this off the top of his head *L*.... Here's a "snippet" of what I found but follow the link for the whole story.... this is a 93 but IDENTICAL issue to yours...
http://earthrenewal.org/are_honda_au...safe_and_r.htm
Another Honda owner related the following experience:
At 66,000 miles (in Feb. 1999), I had my 1993 Honda Accord EX into the local Honda dealer for a major service and checkup. At that time they didn't inform me of the distributor recall. I was under the impression that when a manufacturer has a recall, they send out cards to all the owners informing them of the problem (which I never received). The recall "expired" (never heard of that before.... if a part is defective and a safety hazard, how can a recall expire?) in 1999 and at 75000.
In July 2001, at 94000 miles, the distributor failed with all the symptoms of the recall. Honda refused to budge and fix it. The "screeching" noise was fairly loud above the engine noise. I drove the car with the noise for another 350 miles or so until I got it into my local (and trustworthy) non-Honda mechanic who told me this was common for Hondas from 1993. He said he could either replace the distributor, or try to clean it and lubricate it. I said sure try it. (especially after he told me the distributor goes for $350). Well, it was fine for about a week, and then with my wife driving with our baby in the car, the emissions control light came on and then the car stalled. Luckily she made it back to the house (it was 103 degrees F that day).
I called the dealer, with the information of the recall. He told me about the expiration of the recall and suggested I call Customer Service at Honda. I spoke to the representative, who promised that a supervisor would call me back that day, even though it normally takes 48 hours. Well, at about the end of the day, no phone call. I call the number again, this time another customer service office answered with NO RECORD of my previous call. Oh, and anyway, that recall has expired... So, now I wait again for a supervisor to call who no doubt will do nothing.
I personally feel that something needs to be done to get back at this company. (I was considering to buy one of those new spiffy CRVs, but now will definitely not). Of course, I filed a complaint with the NHTSA online board. I'm considering suing the dealer and Honda in small claims court. Maybe if enough of us do that, or get together and file a class action lawsuit, we might get their attention.
OH, one more thing, in Oct 1999, the day our baby was born, when I returned to the house to get some sleep, the oil seal broke, and dumped oil all over the garage. Again, I found out later that this problem was common for this car because of a defective part. It was quite an expensive fix too because of the labor costs involved. So, if it has not happened to you yet, beware!
This driver's experience with Honda's customer support was similar to my own, except that it took Honda 3 months to get back to me after I submitted the repair documentation they requested. When Honda did reply, the customer service representative indicated that I was fortunate that the igniter was only the second major failure on my vehicle. Honda refused to pay for the repair and refused to offer me an appeal option. The service representative alluded to others with transmission failures (late model Accord V6's) and the front engine oil seal problem (that the above driver referred to).
Old Sep 30, 2006 | 08:52 PM
sir_nasty's Avatar
welll I'm out of here for the next week or so... heading over to Spokane WA for surgery so I'll be back in a while!! Let us know what the fix is, I PM'd CHondivica (sp) and asked his opinion on this so hopefully you'll get some more help with a bit more accurate answers.... Best of luck and let us know the fix!
Old Sep 30, 2006 | 11:42 PM
Chiovnidca's Avatar
ORIGINAL: g1teg
Jeff
See that brown dust in your pic? That's caused by the upper bearing in the distributor crapping out. That's what's making your noise. Need a new distributor.
Old Oct 1, 2006 | 01:43 AM
deserthonda's Avatar
agree with CHIO........ get a dizzy sub assembly..if you let it go as is,, it will cause engine to kick a code and car to die while driving
transfer over the ignitor and coil to the new sub assembly.
Old Oct 1, 2006 | 10:14 PM
  #17
g1teg's Avatar
Yep. I pulled the distributer last night, to take a closer look, And i was almost unable to rotate the shaft by hand. At some points i wasnt able to at all. I sprayed some lube inside it and it freed it up A LOT! am i looking for more trouble driving to work in the morning? or should it be fine to go and get the parts tomorrow? worst case scenario if it freezes?
Thanks guys!
Jeff
Old Oct 2, 2006 | 09:01 PM
  #18
g1teg's Avatar
managed to find a used one with out the ignition coil for 120 CDN. Swapped my coil over and its in the car working great. The problem was definately the bearing. I am going to tear down the old one, if its cool enough ill post a pic of the screwed bearing.
Thanks for the help guys
Jeff
Old Oct 3, 2006 | 05:01 AM
  #19
Slusher's Avatar
Thanks for keeping us up to date with what the problem was. A story with a happy ending...
mjginsrq
Jul 24, 2012 04:26 PM
live2rice
Aug 1, 2008 02:55 PM
cordo88
Apr 16, 2008 09:48 PM
live2rice
Mar 8, 2008 06:19 PM
cbinva
Feb 10, 2008 10:36 AM
