Need Help reading CEL Codes ASAP
Old Apr 22, 2013 | 05:52 PM
Jacob305's Avatar
Default Need Help reading CEL Codes ASAP
i have attached the link to the video of then codes, i just bought a 94 lx coupe 5 speed and shes miss firing so i need help reading the codes shes throwing.
Old Apr 22, 2013 | 06:25 PM
Codes are 9, 15, 17, 41.
Code 9 is No. 1 Cylinder Position indicator (CYP). This sensor fault will cause misfire. Check resistance of CYP sensor at distributor connector first (orn and wht wires or pins 4-8 of conector).
Code 15 is ignition output signal. This might be a false code. See reset.
Code 17 is Vehicle Speed Sensor (VSS). Usually the VSS is faulty and must be replaced. If cruise control doesn't work, this is likely.
Code 41 is Heated O2 sensor heater fault. This means O2 sensor resistance heater is open/shorted. Check resistance of two same color wire pins at connector (usually black or gray).
W/ this many codes, I would first try resetting ECU (pull BackUp Fuse in underhood fuse box. See what codes return before starting any checks.
A shop manual download is available from Online Manuals post in DIY forum.
If you just got the car. Pull the fuse to the ecm, under hood fuse box for about two minutes. Reinstall fuse. Start the car, drive it a bit and see if the cel comes back on. If so, check the codes again.
I read 9, 15, 17 and 41.....currently stored.
Welcome to HAF
EDIT: And TX posted as I was typing.....hey at least we read them the same
Last edited by poorman212; Apr 22, 2013 at 06:42 PM. Reason: reinstall fuse...me big dummy
Old Apr 23, 2013 | 07:09 AM
Jacob305's Avatar
That's a lot of codes lol, thanks guys, I'll reset and check, hopefully there all easily fixed.
brandyn
Nov 26, 2013 05:31 PM
JDS06EX
Feb 22, 2013 02:42 PM
yosoymi787
Nov 1, 2012 09:11 AM
Ryan1984
Jun 21, 2012 01:23 PM
firechicken
Feb 2, 2010 03:20 PM
