Need a motor
Old Dec 29, 2007 | 11:15 AM
CFjdmccord
Default Need a motor
Ok so i have to get rid of the f23 and ive been looking at my options which isnt much lol if besides the 22 if i decided to go f20 what problems would i run into ???
Old Dec 29, 2007 | 11:19 AM
BlkCurrantKord's Avatar
Default RE: Need a motor
Did you mean H22 by "22"?
Either the H22 or F20B is pretty much a direct drop in. Requires some re-wiring of the engine bay and a new ecu. Gonna need a header, one for an H22 will work for the F20B.
Old Dec 29, 2007 | 11:31 AM
CFjdmccord
yea h22 well the wiring well i have a choice between the 2 i got the complete swap just need to decide between the two
im leaning towards the 22 i just dont trust the h series as much i think the f series is more reliable in the long run
Old Dec 29, 2007 | 11:34 AM
sir_nasty's Avatar
to make this more black and white.
Reliability: about the same
Cost: about the same (sometimes)
Economy: Who cares we're looking for power
Ease of Implementation: H22 (lots more documentation on it)
My choice: H22
Old Dec 29, 2007 | 11:56 AM
the h22 and f20b are for all intents and purposes pretty much the same thing, most of the bolt on parts are interchangable(header IM things like that).
the H22 does have a bigger bore, and stroke however, and makes more torque, so to me its a no brainer..........h22 hands down.
Old Dec 30, 2007 | 03:32 AM
F20B - better bottom end reliability. Wiring should be the same as an OBD2 H22.
Old Jan 1, 2008 | 05:11 PM
DA KID RYU's Avatar
I really think its wat u really want..
one hand u have a jdm f20b parts are hard to get but most parts u can get from a h22...
h22 more torque
h22 specifications
Bore × Stroke: 87.0 × 90.70 mm
Displacement: 2157 cc (132 cu. in.)
Valve Configuration: DOHC, 16 valves, VTEC
Type: In-line 4 cylinder, aluminum block and head
Compression ratio: 10.0:1 (North America); 10.6–11.0:1 (Japan)
Max power: 190PS/187hp (CD6 Accord); 200PS (BB1/4/6 Prelude SiR's); 220PS (Euro-R & Prelude Type-S) ;A7 220bhp DIN (Type-R)(142–164 kW)
Max torque: 156–167 ft·lbf (207–217 Nm)
Redline: 7600 rpm
Rev Cut: 7800 rpm
f20b Specifications
Bore × Stroke: 85.0 × 88.0 mm
Displacement: 1997 cc
Compression ratio: 11.0:1
Max power: 180-200 hp (134-149 kW) @ 7000 rpm
Max torque: 141-144 ft·lbf (189 N m) @ 5500 rpm
Yea the h22 has what 10-15 more pounds of torque wow dats cool
but den resleeving the h22 n trying to work with it is a pain in da butt..
both engine's have the same compression ratio
h22 has week insides..
f20b has iron walls.
it has a better tranny short gears
same horsepower as the h22
both are vtec.
Old Jan 2, 2008 | 01:16 PM
falkore24's Avatar
Please use real english
For NA I'd go with the H22. For turbo, I'd go with the F20 and a head spacer gasket to lower the compression..
Old Jan 2, 2008 | 05:29 PM
DA KID RYU's Avatar
ORIGINAL: falkore24
I don't know much bout this topic just some...
what's a head spacer gasket and how does it work to lower compression
what else willyou need to lower compression ratio..
i.e head piston you know...
Old Jan 2, 2008 | 05:34 PM
finch13's Avatar
The head spacer gasket just increases the volume when the piston is at TDC, lowering the compression.
