Need a motor
Old Jan 2, 2008 | 08:03 PM
DA KID RYU's Avatar
Default RE: Need a motor
ORIGINAL: finch13
The head spacer gasket just increases the volume when the piston is at TDC, lowering the compression.
Do you guys know where to getthe head gasket spacer...
how much will it cost me...
and how low will the compression go down...
what's TDC...
thanks guys
Old Jan 3, 2008 | 09:37 AM
falkore24's Avatar
Man .... if you don't know what Top Dead Center is then you have a whole world of reading to do before you can safely own and care for a built turbo engine.
The spacer gasket would most likely have to be custom CNC'd (machined). You can calculate how thick it needs to be from the engine displacement, stock compression ratio and desired compression ratio.
Old Jan 4, 2008 | 12:05 AM
DA KID RYU's Avatar
ORIGINAL: falkore24
Yes, I need to learn alot but that is why im here reading every useful information...
thanks for telling me what it means.
Where should I start reading for turbo
I started from intercooler to bov to the turbo its self..
thanks
yea im a newb...lol
Old Jan 4, 2008 | 09:10 AM
00AccordLX5spd's Avatar
Registered User
I would look all over the turbo section of this site, as well as other sites for some reading. then I would buy a book on turboing a Honda engine.
Old Jan 4, 2008 | 10:37 AM
BlkCurrantKord's Avatar
ORIGINAL: falkore24
Please use real english
For NA I'd go with the H22. For turbo, I'd go with the F20 and a head spacer gasket to lower the compression..
Umm..H22 is 10.5-11:1 compression depending on where and what year the motor is. The F20B is 11:1 no matter what, and where did you come up with head spacer gasket? There is no such thing. You could add a thicker head gasket but that's only going to lower the compression a few thousandths.
Both motors are made for high compression, naturally aspirated power. The H22's sleeves are only weak when it comes to putting in forged pistons.
Edit:Perhaps a deck plate iswhat you mean be "head spacer gasket" ? In which case there are none for the F/H motors and you'd spend more trying to get one made than what it'd be worth.
Old Jan 5, 2008 | 05:48 AM
DA KID RYU's Avatar
So f22 turbo
h22 n/a
got all this thanks.
Woodall
Mar 4, 2014 04:21 AM
Doublel
Mar 11, 2013 07:57 AM
brennonm
Sep 1, 2008 10:42 AM
accord4sroy
Aug 22, 2007 11:24 AM
Markus26
May 17, 2006 09:28 PM
