New guy...New clutch problem
Old Dec 15, 2010 | 07:46 AM
loujitsu's Avatar
Default New guy...New clutch problem
My clutch doesnt seem to engage/disengage. Shifts when off, wont shift when running.
I am pretty comfortable in garage but this one has me stumped....
I replaced clutch (pressureplate/disc/flywheel/seal/bearing/slave/clutch mastercylinder) all oem doorman/perfection etc following service manual.
I bench bled master cylinder before install.
I have tried multiple bleeding techniques.
any advice where to start next>?
Old Dec 15, 2010 | 11:23 AM
Did this begin AFTER you replaced the clutch? Any chance you installed the clutch disk flipped backwards?
Watch the clutch throw-out lever. It should move about 12 mm when someone pumps the clutch pedal.
Old Dec 15, 2010 | 01:04 PM
loujitsu's Avatar
Default clutch probs
thanx for reply
This is a new install and hasnt been driven yet (so after)
I installed disc marked flywheel side to flyweel.
I recorded the movement of the arm and looks good, the company said it only takes like .028 to disengage (perfection, pretty cool dudes) I called around and everybody is baffled.
My next step is to open er up and install my old disc to troubleshoot...kinda a PITA with hand tools but a learning experience.
Old Dec 15, 2010 | 02:36 PM
That .028 is probably the movement of the actual pressure plate. After all the levers & stuff, the movement of 12mm is all the way on the outboard end of the throw-out lever. Or you could say it's the movement of the slave-cylinder's piston-rod.
Before you take it all back out, check the slave-cylinder piston rod. There's a spring inside the slave, pushing the piston outwards against the throw-out lever. You should be able to push on the throw-out lever & compress the slave piston back into the slave cylinder pretty far (probably less than 1 inch). Can you do that?
What I'm beginning to suspect, is the inside end of the throw-out lever isn't properly engaged onto the throw-out bearing.
Is the throw-out lever (#6) properly engaged on the pivot-ball (#7)?
Pull off the rubber bellows (#9) & can you get a look inside to see the throw-out bearing (#5)?
Old Oct 17, 2012 | 01:39 PM
loujitsu's Avatar
Default late reply
thanks for the help.. I wound up putting G-D plate in backwards and swore up and down that it was in the right way. aw well lesson learned
Old Oct 17, 2012 | 02:04 PM
Oh well, like you say lesson-learned.
Anyway, THANK YOU for coming back with the final story. That can help someone who might find this thread when they search about their problems.
vetski179
Feb 24, 2015 04:26 PM
Frankenstein94
Oct 29, 2014 01:02 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
