noise from ABS
Old Aug 28, 2006 | 09:04 PM
accord2006's Avatar
Default noise from ABS
Hi Guys,
I got a 2006 accord coupe V6, sweet ride, but little problem
when i rev from 2k-3k rpm, there's a little noise (squailing/rattle) come out from the engine. 50% of the driving time it does that. I took it to the dealer for service and the guy there told me it's the ABS self test and within specs. Should it be the ABS system error making that noise? Is there any input? the noise irritated the hell out of me.
Thanks guys
Old Aug 29, 2006 | 08:41 AM
YeuEmMaiMai's Avatar
Default RE: noise from ABS
abs self test does NOT do that. The self test occurs as soon as you hit 7-10 mph I beleive. It is usually a clicking noise. I cannot hear it above the radio (I listen to the talk station here in town). the Buzz you hear may be the pump pressurizing the system but that usually occurs right after engine start.
Old Aug 29, 2006 | 12:58 PM
accord2006's Avatar
IT's the VSA kick in I believe from 7-10mph. This noise occur above that speed. i could hear it even traveling speed is 65-80mph, as long as the rpm is between 2k-3k rpm. i turned the music down
Old Aug 29, 2006 | 10:11 PM
have your dealer check your exhaust shields and cat heat shields.
Old Aug 30, 2006 | 12:38 PM
accord2006's Avatar
Sure i'll take that to the dealer again, hopefully that is the problem cuz it would be easy to fix. The last dealer i brought to saying it the ABS self test (within spec). which is bogus. Thanks YEUEMMAIMAI. hey you viet....eh, from where anyway?
stockxplorer
Sep 25, 2022 04:15 PM
93Accord2.2
Nov 7, 2013 07:10 AM
atwood
May 1, 2006 08:59 PM
shinobi16
May 18, 2005 08:21 AM
maxst2
Jan 21, 2005 04:20 PM
