is this normal / blow by
Old Oct 31, 2008 | 03:59 PM
kendo's Avatar
Default is this normal / blow by
i got a 08 accord 4 cyl lx-p while the engine was running i took off the oil cap and the air was blowing out of it like a hurricane,now in the old days with my 92 lincoln we would call that blow - by, that means compression is getting past the rings or valve stem seals, now ive never owned a new car before and not a rice burner,and the car has 4000 miles on it now,its already had its first oil change................any feed back
Old Oct 31, 2008 | 04:44 PM
finch13's Avatar
Default RE: is this normal / blow by
I can't tell you why, but I can tell you it's normal. That's what the PCV valve is for, it allows those gases to go into the intake manifold and recirculated through the combustion chamber again.
Most of the air going through the PCV is from another hose connected from the intake pipe to the valve cover.
http://en.wikipedia.org/wiki/PCV_valve
Old Nov 3, 2008 | 10:37 AM
Crankcase pressure fluctuates up& down as the bottom of each piston displaces air. That fluctuation is much smaller as the number of cylinders is larger. 92 Lincoln V-8 vs Honda I-4??
When the oil cap is open, air is displaced out AND IN. But the inward flow (between outward pulses)is much harder to feel, so it FEELS like its all blowing out.
jsatx
May 2, 2013 09:28 PM
ozman05
Jul 10, 2007 10:14 AM
dbrs0821
Sep 17, 2006 11:58 PM
khedairys5
Sep 16, 2006 08:43 PM
notamechanic
Aug 16, 2006 08:54 AM
