oil leak need help
Old Feb 27, 2009 | 06:35 PM
tomnbarbara
Post oil leak need help
i have an 88 accord
oil leak thought it was the oil pan
changed the pan gasket. still leaking on the back side of the pan theres a hose looks like a return for the oil back to the pan?
above the hose i see the filter and i guess theres a housing for the filter
could the leak be coming from this housing
if so what should i look for replacing the whole housing ? or some kind of seal?
not the oil sending unit turns out it was the rubber oring that goes between the filter base and the block removed the oil sending unit first then the base three bolts into the block cleaned the surfaces installed oring bolts sending unit started car and not a drop of oil
thanks for suggestions from all happy honda once again 188,000 miles
Old Mar 2, 2009 | 10:02 AM
hondatech44
check your oil pressure sending unit ( above your oil filter )
95accordv6
Dec 2, 2011 05:34 PM
pennix3
May 25, 2011 06:14 PM
AkbarGr8
Oct 1, 2010 06:46 AM
ford
Jul 17, 2008 08:29 AM
ahntrio3
Nov 5, 2007 06:15 PM
