91 accord oil leak need HELP
Old May 22, 2011 | 02:28 PM
pennix3's Avatar
Default 91 accord oil leak need HELP
i have a oil leak where the oil is collecting on the back of the engine block drivers side behind the timing belt. i replace the cam shaft seal about to weeks ago what else could be the problem or should i check the cam shaft seal again. thanks in advance
Old May 22, 2011 | 03:12 PM
Tek310's Avatar
Rear main seal?
Old May 22, 2011 | 03:48 PM
Where is the highest point that you see oil on the block?
Old May 22, 2011 | 07:17 PM
pennix3's Avatar
right behind the head up on this little ledge where camshaft at
Old May 22, 2011 | 08:39 PM
Did you put some RTV on the corners of the arc where the valve cover sits on the cylinder head?
Google wYU8qtPzQOY
That video is for a different repair, but start watching at 18 min. He shows how to properly install the valve cover.
Old May 23, 2011 | 01:43 AM
Old Honda Dude's Avatar
Default oil leak
check oil filter base seal. could also be from head gasket oil feed orifice tube. need to remove head for that . its in back of head at center.
Old May 25, 2011 | 02:49 PM
Default 91 oil leak
My 91 Accord has 206355. miles. does not leak a drop of oil. head has never been removed.
Old May 25, 2011 | 06:14 PM
The oil pressure sending unit is also a possible source of an oil leak in that area. It is above the oil filter (kind of way above) and has a one wire connector going to it. That connector has a rubber boot that may be filled with oil to help verify that it is leaking.
95accordv6
Dec 2, 2011 05:34 PM
AkbarGr8
Oct 1, 2010 06:46 AM
tomnbarbara
Mar 2, 2009 10:02 AM
ford
Jul 17, 2008 08:29 AM
ahntrio3
Nov 5, 2007 06:15 PM
