Overheating problem
Old Aug 13, 2006 | 06:47 PM
play4801's Avatar
Default Overheating problem
I have a 1990 Accord ex and I have a problem it keeps overheating if I go about 5 miles and when I turn off the car, water just starts to come out the overflow container so then the next time I leave it will overheat so I have been putting water every time i get home from somwhere.
Old Aug 14, 2006 | 02:59 AM
deserthonda's Avatar
Default RE: Overheating problem
ORIGINAL: play4801
sounds like a stuck closed thermostat
first off make sure that the radiator is full.. if not chk for leaks and repair as needed ..
if no leaks,
start the car and let it warm up,, once engine is warm, the lower rad hose should feel almost as hot as the top rad hose,,,,,,,,,if it feel warm or cool,, you got a stuck t-stat ..
replace and retry .. and make sure both fans come on
search out DIY section there are a few write ups on it
Old Aug 14, 2006 | 03:43 AM
play4801's Avatar
Ok i felt the hose but they are about the same and iam sry i should say stem comes out of the overflow i havent put antifrezze for about a day just water i did that because I didnt want to just keep on putting it in and then buying some more. i have opened up the rad cap to let all the stem just come out......
Stiffy
Jul 9, 2008 09:28 PM
d_10
Aug 21, 2007 08:26 PM
haccord93
Aug 11, 2007 07:03 AM
kennilope
Aug 9, 2007 10:11 PM
jic
Jul 8, 2007 06:48 AM
