plugs and wires
Old Jul 18, 2013 | 08:51 AM
Mikecsti's Avatar
Default plugs and wires
1998 accord v6 ex. What is the best spark plugs and wires to use for gas miles and performace.
Old Jul 18, 2013 | 11:39 AM
NGK plugs are consensus best performers.
New plugs will not significantly help gas mileage unless old plugs are very poor (missing). Plugs are Preventive Maintenance item. You don't wait till the fail to replace.
OEM wires are also very good and will last almost indefinitely in my experience. I would measure lead resistances and check them before replacing. A good check is to spray a generous light water mist on the plug wires at night w/ low/no lights. Check for any engine missing or visible sparks. If you see or hear anything, replace them.
Old Jul 18, 2013 | 12:44 PM
shipo's Avatar
To add to TexasHonda said, you can disregard all of the hype surrounding designer plugs and wires vis-à-vis improved performance and fuel economy. Why? Because it's just that, "hype", in fact, I'd go so far as to say, "scam". Don't be taken in; buy the plugs the very good Honda designers of your car specified for your engine.
Old Jul 18, 2013 | 05:19 PM
What TexasHonda and Shipo stated are true. When I was a lot younger, had more disposable income to just play with and like tinkering with my car, I tried different plugs and many different wires (not just one aftermarket brand). Did they really make any difference? No. More psychological than anything else.
The NGK or Denso plugs (depending on the year, Honda use one or both brands) and the OEM wires are some of the best for your car.
Old Jul 29, 2013 | 04:10 PM
Mikecsti's Avatar
ok thanks guys. the car has ngk "r" it it right now. I think that is for a stock replacement plug so there fine. On the wires ok.
Old Aug 6, 2013 | 05:33 PM
jrock24's Avatar
Were the OEM plugs copper or platinum?
Old Aug 6, 2013 | 06:22 PM
On your car they are regular plugs (copper)
19Accord97
Dec 12, 2007 09:36 AM
Honda_Dude
May 13, 2007 11:20 AM
onedollaraccord
Mar 26, 2007 10:13 AM
patpatho
Dec 27, 2006 04:50 PM
sir_nasty
Mar 10, 2006 01:49 PM
