Quick question about F/H engines
Old Sep 2, 2013 | 02:39 AM
neo31ny's Avatar
Default Quick question about F/H engines
I've been searching and can't find a definite answer to my question. I've heard the F and H series engines are the same block/motor mounts, so would an H22 be a direct bolt in on my '97 accord sedan EX in terms of motor mounts or would I need to swap mounts? According to Hasport two of the mounts are the same, it's the drivers side that differs or what? I'm planning on swapping in an H22 and trying to figure out what all I need, if I can use the stock H22 mounts or a combination of the two engines mounts so I don't have to buy a new set right off.
Old Sep 2, 2013 | 06:23 AM
I "think" if you get the drivers side mount from a prelude you will be fine.....better yet if the engine comes with the mount then you should be good to go.
Old Sep 2, 2013 | 08:11 AM
H swaps have been covered thousands of times on the web.
You can either drill your stock driver side mount to work or buy the haspro one. All other mounts are the same.
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
get'er go'in
May 4, 2010 12:33 PM
noisetank69
Mar 25, 2006 05:39 PM
accord87*
Jan 18, 2006 11:56 AM
9JordonAccord9
Jan 12, 2006 03:11 AM
