quick sanity check
Old Apr 29, 2015 | 06:36 AM
slackreracer's Avatar
Default quick sanity check
last week when trying to repair my wife's 06 accord, I couldn't get any compression. so when I tested the compression checker on my 97 accord, I found out that apparently the gaskets by the spark plugs are pretty much shot. all 4 plug wires were covered in oil. so long story short, looking up new gaskets, and it looks to me that P/N 91301-PT0-003 (O-Ring) from Honda is the gasket that I am looking for, just want to get some reassurance before I buy them.
Thanks in advance.
Old Apr 29, 2015 | 09:07 AM
Most folks replace valve cover gasket and spark plug tube gaskets as a set. Felpro or OEM are both good options.
Old Apr 29, 2015 | 06:44 PM
But is that the correct part number for the OEM gaskets?
Old May 2, 2015 | 11:24 AM
What trim level/engine is in the 97? Either way, if I'm that far into something I would replace the "set"....Upper tube, lower (if non-vtec) and valve cover gasket.
RA1525
Apr 15, 2012 07:50 AM
TooSlow
Mar 7, 2011 12:44 PM
get'er go'in
May 4, 2010 12:33 PM
Brahms
Apr 14, 2008 11:20 PM
thunder_x
Oct 3, 2005 12:35 PM
