Trans problem 02 accord 2.3L
Old May 15, 2015 | 12:48 PM
Moochdog's Avatar
Default Trans problem 02 accord 2.3L
A few weeks ago I bought the accord I always wanted the only problem the dude said it had was that it shifted hard till it warmed up so I drove it an it drove fine so I bought it anyway for 1300 good deal with 170,000 miles and a sun roof. So with going to college to be a auto tech so I did some more looking n I found it was low on oil an the trans fluid was low an it had a few code so I got it down to 2 codes which are p0700,p0780 with the flash D4 light and I change all the solenoids and it still shifts hard an goes in too limp mode but it fluid it's still red no metal in it.sometimes it'll stall when I 1st crank it up an put it n 1 or 2 gear. So what I'm trying to do is rule out getting a trans for it now but I will if it comes to it
Old May 15, 2015 | 04:13 PM
You may have done what shop manual says can be done mechanically to repair.
Manual says to replace trans if codes return after replacing torque converter clutch solenoid valve/shift solenoid valve A and AT clutch pressure control solenoid valves A & B, and resetting PCM.
You might consider draining/replacing ATF w/ Honda ATF. Three sucessive drain/replace/drive cycles will replace most of old ATF. Some have had good results w/ this simple fix.
Old May 15, 2015 | 06:17 PM
Moochdog's Avatar
Thanks for the advice from driving it doesn't seem to slip at all. The day I found it was low on fluid I put two bottles in an it ran like a new car an clear codes codes It had but after it cooled down it shifted hard again an went in to limp mode. But yesterday I noticed that when I pulled the dual linear solenoids off I seen the 3 metal pipes that had like black surface that came off on a q tip
ECV4LIFE
Apr 15, 2010 08:09 PM
jroe_28
May 11, 2008 08:11 AM
BLAS0827
Jan 9, 2007 12:11 AM
bmarshall
Jan 3, 2007 08:54 PM
mbo1985
Mar 25, 2006 04:07 PM
