recent engine swap
Old Dec 21, 2011 | 10:43 PM
Eazysc's Avatar
Default recent engine swap
I have a 94 honda accord lx and i recently got a f22b1 vtec out a 95 accord ex I was wondering will this engine work in my 94 accord lx and if so am i suppose to use the engine wires to firewall off my old engine or keep and use the ones off the f22b1 vtec engine??
Old Dec 22, 2011 | 08:36 AM
You may have some problems driving the vtec system w/ your old harness. Harness does't have wiring and connectors. I believe others have had to splice in wiring for this system. Not too difficult is my recollection. A search should yield some results on this problem.
Old Dec 22, 2011 | 08:31 PM
Eazysc's Avatar
the only problem im havin now is its turnin over but not catching to start its firing and fuel reachin system and it has compression and the engine was running wen i took it out the car i drove it to my house to take it out the night b4
Old Dec 23, 2011 | 02:55 PM
Something's missing if it's not running. Suggest attempting to start w/ 3-5 second spray of throttle body cleaner or starter fluid. If no kick-over of engine, spark is suspect even if you're seeing spark jump gap on a spark plug. Suggest testing spark w/ a timing light on one or more spark plug leads. No flash means no spark in cylinder.
After an engine installation it's easy to leave important ground leads loose. Check ground at thermostat housing as this enables spark.
If engine kicks over, then spark is good and fuel pressure/delivery is suspect. Check ignitors are firing, fuel pressure.
HondaAccordEX94
DIY Answers.
Apr 1, 2010 04:45 PM
thunder_x
Feb 9, 2008 01:58 AM
sir_nasty
Sep 25, 2006 04:24 PM
RTexasF
Jun 13, 2006 01:52 AM
etcotter
Jan 23, 2006 02:27 AM
