replacing engine from dx to vtec
Old Feb 19, 2012 | 10:23 AM
MoreNice's Avatar
Smile replacing engine from dx to vtec
hey there, i have 1999 honda accord dx 4 cylinder regular engine, and im replacing the engine with a 1999 honda accord 4 cylinder vtec engine, but
i dont want to intall the vtec, is it possible and if so will it bring problems later on.
Old Feb 19, 2012 | 12:42 PM
I suppose it could be done if you just use your stock wiring harness and stock ecu, in theory the engine would run just without vtec. Never heard of anyone doing though, as the VTEC will only help not hurt.
All you have to do is add one or two wires for vtec and get the vtec ecu to make it work
Old Feb 19, 2012 | 02:56 PM
MoreNice's Avatar
Well the thing was that my engine some how over heated, engine went bad so I found new vtec engine same year car but only because it was cheaper than non vtec engine, and I don't want to buy
New wires and computer so I'll just not install the vtec, but wanted to make sure it was going to work
Thank you
Old Feb 19, 2012 | 08:03 PM
I wouldn't be surprised if your car's wiring harness has the wires necessary for the VTEC circuits. It's only a couple wires out in the engine compartment thats needed. Proabbly nto too difficult to do.
Old Feb 19, 2012 | 09:15 PM
MoreNice's Avatar
I'll keep an eye open for wires and the rest of the stuff ill keep it posted and let you know how it went in two more days
Old Feb 20, 2012 | 08:27 AM
g22cd5's Avatar
Supper Moderator
How to wire vtec - HondaSwap Forums
you need to wire vtec if it's a vtec engine. otherwise you will burn oil since sohc vtec is low end not high end. You can get away with no runnin vtec in DOHC vtec engine since your rarely in vtec (unless you redline every gear) since it's all high end in the RPM power band.
Old Feb 21, 2012 | 08:55 PM
MoreNice's Avatar
If I do the hot wiring do I need a vtec ECU or my regular stock one?
Old Feb 22, 2012 | 01:14 AM
g22cd5's Avatar
Supper Moderator
yes you need the ecu that is for your engine. if it's a f23 vtec then you need the f23 vtec ecu.
cg31998
Dec 15, 2010 10:29 AM
kris_loehr
Dec 19, 2008 07:20 PM
imjrk
Nov 25, 2007 08:36 AM
94coupeaccord
Feb 7, 2007 05:01 AM
