RPM'S
Old Apr 6, 2007 | 01:34 PM
dmtz
Default RPM'S
I have a 1996 Honda Accord V6. I have recently noticed that at cruising speeds my RPM meter is all over the place. Now it happens just about every time I get into the car. I have replaced plugs/cables, new cap and rotor. Since I have had the Engine light come on, but it turned out to be the EGR valve which I have replaced. Has anyone experienced there RPM meter dance all over the place, occasionally I do feel the car jerk, but not often. Any help is welcomed and I Thankyou in advance.
DMTZ
Old Apr 6, 2007 | 01:40 PM
smaglik's Avatar
Default RE: RPM'S
Is it just the meter, or do the RPMs go along with it? It's hard to tell from your post.
Old Apr 6, 2007 | 01:42 PM
dmtz
Default RE: RPM'S
Its just the METER.
Old May 20, 2007 | 01:57 AM
tupelolaosthaboi
Default RE: RPM'S
mite just be tha sensor?
Old May 20, 2007 | 02:32 PM
00AccordLX5spd's Avatar
Registered User
Default RE: RPM'S
Dude...this sounds just like my problem: https://www.hondaaccordforum.com/m_56200/tm.htm
Read this thread and see if you think we are suffering from the same problem.
Looks liketwo of the forum experts think it could be the ignition coil on mine so I am going to go buy a VOM and test it out.
Have you pulled the Check Engine Light codes?
Old May 20, 2007 | 10:40 PM
Chiovnidca's Avatar
Default RE: RPM'S
ORIGINAL: dmtz
The ignition coil is a common cause of that problem on a v6. There's a resister in the coil that the tach is driven through, they tend to crap out.
Old May 20, 2007 | 11:16 PM
Registered User
Default RE: RPM'S
OK...now 3 of the forum experts say it is probably the ignition coil! I am sure that is probably the problem on both of our cars. I'm going to try to find a VOM tomorrow and also check out the prices on ignition coils.
Old May 21, 2007 | 11:57 PM
KevinAccord's Avatar
Default RE: RPM'S
i agree with 00accordlx5spd. i've heard the same thing a few times. it must be that, otherwise, u'll have to buy a new cluster, which is not so cheap.
Old May 22, 2007 | 07:28 AM
Default RE: RPM'S
Kevin, you've got a 2000 4-cyl, right?
I think your tachometer signal comes from the ECU, like it does on my '98 4-cyl.Some cars the tach signal comes from the ignitor (not the coil), but apparently on the V-6 it comes from the coil.
inspector9
May 23, 2012 05:16 PM
santiagueƱo
Jan 8, 2006 05:11 PM
Chicago
Dec 3, 2005 10:45 PM
Trens
Aug 3, 2005 03:22 PM
My wifes honda
May 24, 2005 02:59 AM
