Sohc or Dohc?
Old May 6, 2007 | 02:26 AM
Honda_Dude's Avatar
Default Sohc or Dohc?
i have an 1998 Honda Accord 3.0L V6 and I've heard many people say it is a Dohc but some people say it is a Sohc? I'm totally confused... Which is better and which one do i have??
Old May 6, 2007 | 09:43 AM
Chiovnidca's Avatar
Default RE: Sohc or Dohc?
sohc
Old May 7, 2007 | 01:15 AM
BATerrell's Avatar
It is a SOHC. You have 1 cam under each valve cover.
Engine ID is probably J30A blah blah...
Old May 7, 2007 | 02:43 AM
legionofone's Avatar
TECHNICALY DOHC but if it was true DOHC it would be QOHC thus if u were refering to it in the normal sence u would call it a SOHC
Old May 7, 2007 | 04:13 PM
Honda_Dude's Avatar
technically dohc? i am thinking about putting a decal on the side of my car and i dont want to to but the wrong one.
Old May 7, 2007 | 05:08 PM
KevinAccord's Avatar
each side of the v6 engine has one over head cam which makes i a sohc, but, since there's two, legionofone refers to it as technically dohc which is not incorrect, he'sjust adding both over head cams, which i guess that was what he meant. but if you are gonna put a decal it should say sohc.....hope it helped!
Old May 7, 2007 | 05:33 PM
Honda_Dude's Avatar
thanks Kevin..it sure did...wat would you recommend on spark plugs for a my car that onlt has an SRI??
Old May 7, 2007 | 09:27 PM
BATerrell's Avatar
Stock NGK and some NGK Blue wires. Might as well do your distributor cap and rotor, too.
Old May 7, 2007 | 09:29 PM
sir_nasty's Avatar
I don't know if anyone else has noticed this or not but Accord plug wires are spendy..... I've found that it's only like $10-$50 more (depending on what set you're looking at) to get a good set of Nology wires....
Old May 16, 2007 | 01:03 AM
YeuEmMaiMai's Avatar
All current J series V6 are SOHC in the USDM including the newest 3.5L and 3.7L used by acura
hypnoticxhyphy
Apr 17, 2007 06:16 AM
Honda_Dude
Apr 5, 2007 06:22 PM
wjmj
Jan 7, 2007 10:57 AM
len1967
Oct 16, 2006 11:43 PM
