Spark Plugs / Wires -7th Gen
Old Jul 14, 2007 | 12:10 PM
03Sleeper's Avatar
Default Spark Plugs / Wires -7th Gen
1. Is it worth it?
2. Where are they located/how to install.
This was because of this...I've heard good things about Iridiums and I'm sticking with OEM wires (forum reading says Honda wires are top notch).
http://cgi.ebay.com/ebaymotors/DENSO...QQcmdZViewItem
Old Jul 14, 2007 | 01:49 PM
sir_nasty's Avatar
Default RE: Spark Plugs / Wires -7th Gen
I've never used them but people who have them seem to like em, Given your engine setup I'm not sure how much you're going to gain over stock NGK plugs but it may be a little smoother....
Old Jul 14, 2007 | 02:25 PM
RTexasF's Avatar
Super Member
Since the plugs run $12-$15 each I would think it's a good buy. I didn't see anything specifying they were brand new. Unless you have75,000 miles +on the old onesI doubt you'ld notice any difference.
Old Jul 15, 2007 | 12:56 AM
03Sleeper's Avatar
Funny thing you mention that....I have 89k on this beast. It's hard to believe I got it brand new in 2003. :-/
All of our products are DENSO Genuine and 100% Brand New.
Yeahh...I read the manual and it blatantly states it uses DENSO Iridium tipped spark plugs....so more or less its an OEM change.
Old Jul 15, 2007 | 05:02 PM
2003 4-cyl has NO plug wires. There's a coil pack on each spark plug, NO distributor, & NO plug wires.
Stock NGK or Denso plugs should be OK since you're not boosting or using NOx.
Old Jul 15, 2007 | 08:49 PM
03Sleeper's Avatar
Yeah, just just plop them into the coil pack.
Old Jul 15, 2007 | 08:56 PM
smaglik's Avatar
so did you find links selling wires for the 7th gen?
Old Jul 15, 2007 | 10:38 PM
03Sleeper's Avatar
Erm...what do you mean?
Old Jul 16, 2007 | 03:45 PM
ORIGINAL: 03Sleeper
Unless "2003" was a typo, your car does not have a distributor. Mine doesn't...
It doesn't use plug wires at all. Each spark plug has it's own coil (#1) and the 12v wiring harness connects directly to each coil.
Old Jul 16, 2007 | 04:21 PM
03Sleeper's Avatar
Right...I'm just replacing spark plugs...not wires...since I don't have any.
sirtwist2
Sep 24, 2012 01:36 AM
nukestar88
Feb 28, 2011 10:20 PM
onedollaraccord
Mar 26, 2007 10:13 AM
patpatho
Dec 27, 2006 04:50 PM
accord4sroy
Mar 21, 2006 12:41 PM
