Tachometer bouncing?
Old Feb 2, 2007 | 03:05 PM
nitro74d
Default Tachometer bouncing?
Hello, I have a 1996 Honda Accord, and lately the tachometer is bouncing when I am driving, it will bounce from 1 to 4 continuously, and then sometimes it will doit just a little to none. The car is having no issues while this is happening so I am sure it is just a loose connection or tach. is going bad, or a fuse. But, was wondering if anyone has had this happen or knows what it might be. I am getting ready to move accross country and would like to know that it isn't somthing serious just to be sure.
Thanks for any help,
Charles
Old Feb 2, 2007 | 03:07 PM
sir_nasty's Avatar
Default RE: Tachometer bouncing?
easy test to do.... in the engine bay on the drivers side you'll find a blue two wire plug, that's an external tach connection, get a tach and hook it up to it and see if it does the same thing, if it reads/acts normal then you know you've just got a bad tach, then I'll give you a link (or you can search the forums) for a free manual and change it yourself easily....
Old Feb 2, 2007 | 04:47 PM
legionofone's Avatar
check the connections to the tach u might have a loose wire or ground...
Supernaut
Mar 12, 2011 08:27 PM
mrquettfan
Nov 24, 2010 01:02 AM
davisi
Aug 22, 2010 04:26 PM
o CRA5H o
Oct 26, 2009 07:08 AM
nitro74d
Feb 2, 2007 03:23 PM
