tapity-tapity-tap
Old Oct 9, 2007 | 05:49 PM
thaxman's Avatar
Default tapity-tapity-tap
OK, so now I have a tap appearing at idle. I assume its valve related, but w/an OHC, its not a rocker arm. My CRX had a whole valve cover full of knocks at idle - this sounds like 1 valve. Is this common & should I get it taken care of ASAP?
Old Oct 9, 2007 | 09:49 PM
Default RE: tapity-tapity-tap
The valve tappets are just like rocker arms. There's an adjustment screw at one end. On SOHC Accords the valve lash is measured at the valve stem, not at the camshaft lobe. Check & adjust when cold. Lash should be printed on a sticker under the hood.
Old Oct 10, 2007 | 02:57 PM
falkore24's Avatar
I'd give this a shot:
1) engine flush
2) Marvel Mystery Oil
3) after 3000 mi, engine flush at normal idle for 5 minutes
accord05thirteen
Jan 9, 2015 12:10 PM
accord05thirteen
Nov 19, 2014 01:29 PM
Davidwhittle76
Apr 12, 2012 11:18 AM
dave1977nj
Feb 28, 2011 10:41 AM
MakoMan
Jun 28, 2007 07:44 AM
