Vtec Block
Old Feb 12, 2007 | 09:32 PM
BuntinBoy9's Avatar
Default Vtec Block
Hey i own a 94 accord sedan thats a five speed. it is a non-vtec engine f22b2. i was wondering if i could make it vtec by dropping a top vtec block on the top of it. yes??? no???? i have heard both. thanx
Old Feb 12, 2007 | 10:50 PM
poser_pilot6
Default RE: Vtec Block
Hmmm. Well if you drop an engine block on your engine, you will likely break things. However, if you mean "can I put a vtec cylinder head on my non-vtec F22B2 and make it a vtec?" then the short answer is yes. But you will need the head and everything it entails, along with some (if not all) of the wiring from the vtec engine, and most likely the ecu out of the vtec car as well. But it can be done!
Old Feb 13, 2007 | 01:28 AM
legionofone's Avatar
u need to basicly get everything but the block out of a Vtec engine swap...
Old Feb 13, 2007 | 10:24 AM
HondaRacer4Vtec's Avatar
i Rather just get a new engine then doing all that stuff. Myabe a h22 or if you wanna stick with f seris engine then f23A1
Old Feb 13, 2007 | 06:23 PM
h22 head on a f23 is better than a h22 all around... h22 bottom end sucks...
trukid21
May 4, 2012 02:44 PM
FarRockAccord
18
Feb 1, 2008 06:36 PM
EMEX
Mar 21, 2007 02:08 AM
94coupeaccord
Feb 7, 2007 05:01 AM
