vtec controller
Old Dec 22, 2008 | 02:40 PM
baconsum1's Avatar
Default vtec controller
i got this vtec controll for my 94 accord never used it so i'm thinking about putting it my 2000 accord. it says it makes the vtec kick in at a lower rpms. i hear alot about it so i got mixed thoughts about it.is it wise to put in my car?what would i gain from it?
Old Dec 22, 2008 | 02:43 PM
finch13's Avatar
Default RE: vtec controller
Brand? Pics?
Can you adjust it?
falkore had one...
Old Dec 22, 2008 | 02:50 PM
baconsum1's Avatar
baconsum1's Avatar
[*]Tiny specification for easy placement. Digital LCD.[*]Inbuilt RPM gauge for easy operation prior to setting. [*]Release the torque and horsepower in advance when the engine is in low RPM.[*]Working up the VTEC pontentiality.[*]Changeable ratio of hi-camshafts working; available in every +/- 100 rpm.[*]Size: 2.25" (L) x 2" (W) x .75" (H), baby VTEC controller easy to intall to almost anywhere. [*]No instructions included. Professional installation is highly recommended.
Old Dec 23, 2008 | 06:10 PM
falkore24's Avatar
Better off buying my V-AFC2. Static setpoints are all fine and dandy, but engaging VTEC too low will cause bogging. Also, the major benefit of this type of system are the override triggers that this doesn't have. My Apexi unit has triggers for intake vacuum setpoint and throttle position. For example, I had it set to engage VTEC as soon as I hit 65% throttle.
$80+shipping FYI
Old Dec 23, 2008 | 11:23 PM
baconsum1's Avatar
so what will i be gaining from this product?
Old Dec 24, 2008 | 09:08 AM
falkore24's Avatar
You can adjust the VTEC engagement point, but without the additional programming or tunability, you are better off with the stock dynamic control of the VTEC system.
Roadrash98vtec
Jan 15, 2009 05:24 PM
Joseph
Dec 21, 2007 08:44 AM
vtecpower7788
Oct 30, 2007 03:48 PM
accord2k
Jul 9, 2006 01:48 PM
