whining noice in the engine bay??
Old Oct 17, 2006 | 09:14 PM
Leonhartilly's Avatar
Default whining noice in the engine bay??
i own a 98 accord coupe
Im assuming its my alternator because thats where the sound is comming from. The belts. when i start my car, the car starts but then it just dies down. What i mean in detail is, the starter ignites the engine but it seems like it isnt enough and i just hear a bbbbrrrr.... This only happens once in a blue moon. Maybe once every 5 months since i've had it. I've owned it for over 1 year and a half.
am i correct? but the thing is, i got my alternator tested but it passed. So it must be one of those intermitting problems. I just dont want to spend 300$ because im saving up for college and i also want to pimp out my ride next summer.
Old Oct 17, 2006 | 09:18 PM
YeuEmMaiMai's Avatar
Default RE: whining noice in the engine bay??
is it a V6?
If it is then most likely it is your alt. Those things are DELPHI POS....
Old Oct 18, 2006 | 01:38 AM
Chiovnidca's Avatar
ORIGINAL: YeuEmMaiMai
is it a V6?
X2
I replace so many of those i could probably do em blindfolded.
Old Oct 29, 2006 | 03:36 PM
sorry i forgot to mention its a 4 Cylinder. Now what kind of Alt should i replace it with?
Old Oct 30, 2006 | 06:41 PM
sir_nasty's Avatar
All I can say is don't get an alternator from Checker/Schucks/Kragen... most NAPA alternators that I've used held up good...
Old Oct 30, 2006 | 07:46 PM
deserthonda's Avatar
before you replace anything, make sure that it is what is causing the problem,,
if you are not sure about the alternator being noisy,, put a big screwdriver on the alt and on your ear to locate the noise ( engine running ). also do it on the a/c compressor and p/s pump..if stil not sure remove the belt and start the car without the belt , if noise goes away, by hand spin the alternator and the a/c pulley ,that should tell you which is the culprit , If the noise is still there with the alt belt off,, remove the p/s belt and try it again ,, if noise goes away you got p/s pump noise,, if noise is still there with both belts off,,could be the water pump or t-belt idler,,
let un know what it turns out to be
Old Oct 30, 2006 | 09:36 PM
could be differential in transmisison as well
letsclique
Dec 28, 2012 03:57 PM
R34Accord
Mar 22, 2007 09:01 AM
19Accord97
Mar 21, 2007 07:24 PM
R34Accord
Mar 20, 2007 11:27 PM
cgarcia275
May 15, 2005 07:47 PM
