wont start in hot weather
Old Jun 19, 2007 | 04:20 PM
99cummins
Default wont start in hot weather
today it was probably 85 and raining so i couldnt put the windows down. went out to start the car after work and all it would do is turn over as if it wasnt getting fuel or spark. the kid i bought it from had this problem last summer but this is the first for me. i usually put the windows down halfway through the day so it doesnt get so hot. any
any ideas would be appreciated thanks
Old Jun 19, 2007 | 05:02 PM
Default RE: wont start in hot weather
Main relay comes to mind when you say the cabin was really hot.
Some have bad solder joints, if you know how to solder it's easy to fix them.
Old Jun 19, 2007 | 06:09 PM
99cummins
will it still turn over if the main relay isnt working??
where do i find it
Old Jun 19, 2007 | 10:57 PM
If the main relay was bad, the starter would still turn over the engine. The main relay switches the fuel pump (among other things) so it wouldn't get any fuel.
Check this out...
http://techauto.te.funpic.org/mainrelay.php
It's a little weak about exactly where to find it, but Honda always seems to put the main relay sorta above thedriver'sleft kickpanel.
Old Jun 20, 2007 | 05:02 AM
99cummins
ill try fixing that tonight
thanks alot!
Old Jun 25, 2007 | 09:59 AM
ducatiff's Avatar
Main relay is the problem. I had it happen to my 90. If you it happens and you are in a pinch, turn the car on and crank the engine and at the same time pop the underside of the dash with your palm, sometime that will switch the relay to get it going. I bought a new one from Honda because if happened to my wife and lets just say she wasn't happy. I think it was like $135bucks from Honda though.
drumm3r7
Apr 29, 2013 06:42 AM
gasface11
Jul 11, 2012 12:33 PM
jstrick
Jul 14, 2010 07:16 PM
tris320
Jun 16, 2010 11:08 PM
japo2336
Jul 16, 2007 09:49 PM
