[2001-6G] Spark plug wire order on distributor? All confused. Got a photo?
Old Sep 5, 2007 | 08:48 PM
helixblue
Default [2001-6G] Spark plug wire order on distributor? All confused. Got a photo?
Had a spark plug wire pop off today and damage itself. When replacing it with new ones, like a doofus, I took two wires out instead of one. What's the order that they go in? I tried to search for an engine photo on Google Images, but none were high enough quality to follow the wires. The car is a 2001 Honda Accord 4-cyl (2.3L VTEC, 6th Gen). The order I have right now is:
Top Front Distributor Cap -> Cylinder 1 (leftmost)
Bottom Front Distributor Cap -> Cylinder 2
Top Rear Distributor Cap -> Cylinder 3
Bottom Rear Distributor Cap -> Cylinder 4 (rightmost)
I'm pretty sure this is wrong. It's not firing up and I'm afraid to try multiple combinations because supposedly it may damage the engine? Thanks for your help. I learned me a new lesson tonight.
Old Sep 5, 2007 | 11:07 PM
deserthonda's Avatar
Default RE: [2001-6G] Spark plug wire order on distributor? All confused. Got a photo?
if you look at the cap there should be an A stamped on it or a1 depending on the cap there is # 1 cylinder . from then you go clockwise 1-3-4-2
# 1 ,, left botton
# 3 ,,left top
# 4 ,, rt top
# 2 ,, rt bottom
http://autorepair.about.com/library/...bl-fo-2405.htm
Old Sep 6, 2007 | 06:03 AM
helixblue
Awesome. I found a stamp labeled A1, and followed it from there. The car fires right up happy as a clam. Thanks!
Old Oct 22, 2007 | 05:48 PM
Silverad04
is this the same for the non-vtec 4 cyl. in a 95 accord?
Old Oct 22, 2007 | 06:15 PM
There is a link in a thread at the top of the DIY section for called ACC 5th gen.... If you open the electrical pdf, the page is 23-102 for the dist firing order on a 94 4-cylinder.
Old Oct 22, 2007 | 11:02 PM
All inline 4-cyl engines have the same firing order 1-3-4-2. Honda has stamped something like A or A1 at distributor post #1 for a long time. That method should work for a pretty wide range of Hondas & Acuras.
Fredcheesemonkey
Apr 21, 2013 09:40 AM
vermonter86
Jan 1, 2012 07:32 PM
MessAround
Jul 2, 2011 07:47 PM
HONDA90
Oct 1, 2007 10:54 AM
mck52689
Jul 14, 2007 02:11 PM
