'00 Accord Dash lights
Old Oct 15, 2007 | 12:00 PM
advokat
Default '00 Accord Dash lights
Sometimes the dash lights will just go out for no apparent reason. If I tap on the plastic shield they will sometimes come back on. I've disassembled the unit and replaced bulbs, looked at wiring, etc.-everything seems okay. Has anyone ever seen this before or know of a good fix?
Old Oct 15, 2007 | 04:32 PM
00AccordLX5spd's Avatar
Registered User
Default RE: '00 Accord Dash lights
The way you described it, it definitely sounds like a faulty connection somewhere. Other than examining every wire, I cannot really think of anything.
Old Nov 5, 2007 | 07:14 AM
advokat
I pulled the cluster and it turned out that the far left harness connector had some play in it. I shimmed it with a small piece of wood and problem solved. Hope this helps someone else.
Old Nov 5, 2007 | 07:36 AM
falkore24's Avatar
Thanks for posting the fix!!!
Vettress
Jul 7, 2010 11:10 AM
natthefisherman
Apr 12, 2010 11:20 PM
eccsc01
Feb 28, 2008 07:07 AM
marky4
Sep 7, 2006 01:25 AM
marky4
Sep 5, 2006 03:21 AM
