00' v6 accord won't shift??? Help
Old Mar 11, 2013 | 09:21 PM
jaybird1ton's Avatar
Default 00' v6 accord won't shift??? Help
I have a 2000 accord v6 automatic. 212000 miles. car is in great shape but has a problem shifting from 3rd gear to 4th gear. You can start out in first gear and manually shift it to 2nd then build a little speed and skip 3rd and go into 4th and it does fine, but if you shift it in 3rd there is nothing. There are no noises in the tranny. I heard that it might be a solenoid? Is this true and which solenoid would I replace? The car is not throwing any codes. Anyone have any ideas? Thanks
Old Mar 11, 2013 | 11:57 PM
go-part's Avatar
Former Sponsor
Test the ones you can find. You should have somewhere between 12-25 ohms of resistance.
Old Mar 12, 2013 | 08:24 PM
Thanks!
Old Mar 13, 2013 | 01:17 AM
Good post with answers..Thanks Go-part.com
Old Feb 28, 2016 | 12:08 PM
Marcos Eljienyo Santos's Avatar
I have a 98 accord and when u put it in 1st gear it drives fine but once u try and put it in second gear there's nothing there almost like its in neutral but I drove it from first and shifted it to third and it takes awhile to catch but when it does it drives fine
Old Feb 28, 2016 | 01:57 PM
shipo's Avatar
How is the fluid level in the transmission?
Old Feb 29, 2016 | 11:45 AM
Marcos, is yours a V-6 automatic like the original poster? If not, is it automatic or manual transmission?
I only ask because you talk about shifting 1st to 2nd to 3rd...
rydnlow1120
11
Nov 11, 2015 05:29 PM
coolaccord
Jul 15, 2014 01:07 PM
83Daley
Jul 7, 2009 09:10 PM
thunder_x
Oct 24, 2007 10:26 AM
hondadad69
Jul 26, 2007 05:17 PM
