01 accord v6 EX sedan EGR problem.
Old Jun 29, 2012 | 12:22 PM
ericspyder's Avatar
Default 01 accord v6 EX sedan EGR problem.
Hi,
I have a 01 V6 accord sedan. Recently, it have check engine on, I used OBDII reading that was EGR valve problem. I cleared the code, it came back about 4 weeks later.
I talked to a mechanic, he told me that the valve getting dirty, and he can clean it by using some long cleaning cable or something.
Do you think what he said is right? Is it easy to do? Do we have any DIY post about that? Thank you.
Best Regards,
Eric
Old Jun 29, 2012 | 12:27 PM
What was the actual trouble code(s)?
Your generation Accord V6 were prone to the EGR ports getting clogged. Honda had a technical service bulletin showing the cleaning procedure.
Old Jun 30, 2012 | 03:31 PM
ericspyder's Avatar
Thank you for reply. Unfortunately, I clear it off. Now I couldn't find it. But where can I find the technical service bulletin showing the cleaning procedure? I very appreciated. Thanks again.
Eric
Old Jun 30, 2012 | 04:03 PM
This link is for the Honda TSB:
http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
I also attached a picture of another EGR port on the engine that people sometimes miss cleaning, since it is not illustrated on the TSB. This is the port referred to in step #15 of the TSB.
Essentially, the EGR port cleaning should be done on the intake manifold and the engine.
Attached Thumbnails 01 accord v6 EX sedan EGR problem.-step-15.jpg   01 accord v6 EX sedan EGR problem.-engine-port.jpg
Old Jul 2, 2012 | 12:19 PM
ericspyder's Avatar
Thank you so much. It'll help me a lots.
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
newbieny
Oct 22, 2009 05:17 PM
RJLhonda
Sep 9, 2008 01:05 AM
ss927
Mar 11, 2008 12:25 PM
AccordEX
Oct 12, 2007 03:58 PM
