01 Auto Tranny fluid change
Old Aug 1, 2007 | 04:18 PM
accordfan's Avatar
Default 01 Auto Tranny fluid change
Ok...the instructions in the owners manaul are just nuts...drain, fill, drive, drain...repeat 3 times!
Is there not an easier way to get ALL the fluid out at one timebesides the crude method described in the owner's manual??
All that wasted new fluid...just GOTTA be a better way without fancy transmission shop tools.
Old Aug 1, 2007 | 04:39 PM
sir_nasty's Avatar
Default RE: 01 Auto Tranny fluid change
Don't use fancy transmission tools, those flush systems are not good for your tranny. Personally I'd just make sure the car was level, drain as much as you can and then fill it up and call it good. Be sure to use Honda ATF.
Old Aug 1, 2007 | 06:31 PM
accordfan's Avatar
but that will leave lots of old fluid in the system...
Old Aug 1, 2007 | 09:53 PM
smaglik's Avatar
it wont leave that much. if you're really concerned, repeat the procedure twice. i would only do that if the fluid looked burned.
Old Aug 2, 2007 | 02:19 AM
deserthonda's Avatar
if the fluid looks pretty clean ( reddish ) color just do a drain and refill .. if fluid looks pretty black and or smells like burnt ,, repeat the drain and refill 3 times
drain it, refill, drive the car for a bit,
drain and refill, drive car again
drain and refill
you will need 9 qts of fluid , use only Honda ATF-Z1 , cost per qt $ 6.07..
after that make sure to replace tranny fluid at no longer than 30,000 miles interval,, if you have the extra money do it every 15,000 miles or once a year
Old Aug 2, 2007 | 08:56 AM
ORIGINAL: smaglik
With an automatic tranny, the torque converter doesn't drain. So you can only drain about 1/3 of the total fluid.
My '98 auto tranny specs say 2.6 quarts when you drain & fill (about what I'd say from experience)out of6.6 quarts total fluid.
Old Aug 2, 2007 | 05:32 PM
accordfan's Avatar
So what I'm reading is...there is no way to drain it all at one time.
Bummer
Old Aug 2, 2007 | 05:43 PM
Chiovnidca's Avatar
ORIGINAL: accordfan
Bummer
Nope. Just drain and fill. I'd reccomend doing it a bit more often than honda says.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
Kazoo2U
DIY Answers.
Jun 24, 2012 03:12 AM
93Accord2.2
Jan 20, 2012 01:02 PM
62maxx
Nov 21, 2006 12:04 PM
