02 accord 4cyl AC problem
Old May 30, 2011 | 06:55 PM
charless21's Avatar
Default 02 accord 4cyl AC problem
I have a 02 accord se with AC problems. The blower works but only hot air is coming out. Coolant was checked and is good. I don't think the compressor is coming on. Could the relay switch be bad? Or worst will I need a new compressor?
Old May 30, 2011 | 09:08 PM
gapeach76's Avatar
I have the same problem with my 2000 accord 4 cylinder. I think it is the a/c switch, which I ordered, but can someone tell me where it is located?
Old May 30, 2011 | 10:39 PM
bugjohnson's Avatar
Need to know what could be wrong with air conditioning issue. I have a 1999 Honda Accord that the air will blow out but the lights on the panel goes out. Sometimes they are okay and then sometimes they will go out. Could this be some type of control module?
Old May 31, 2011 | 01:02 AM
deserthonda's Avatar
guys you cannot hijack threads like this ,,,,we got 3 car with a potential 3 different problems
Charless 21 ,, chk the fuses first , coolant has nothing to do with a/c system unless you mean freon was checked ,,if so how did they chk it ?? is there power at the compressor wire ?? both fans coming on ??
gapeach ,, Do Not start replacing parts till you properly diagnose the issue
Bug,, it could be a control panel issue it could also be a poor connection ,, Need to diagnose
kenwood guy
Sep 15, 2013 03:02 PM
guyj1
Jan 3, 2009 10:13 PM
d_10
Aug 21, 2007 08:26 PM
1999accord_SC
Jun 19, 2007 03:01 PM
elprezidente
May 4, 2007 09:26 PM
