02 Accord,Plugs,Wires cap & Rotor, Help selecting
Old Sep 3, 2013 | 12:57 PM
JOE.G's Avatar
Default 02 Accord,Plugs,Wires cap & Rotor, Help selecting
Hi, I have been changing the plugs, wires,cap n rotor every 50,000 Miles, I have used factory parts. Any suggestions on other brands? Maybe NGK wires or something, Can I get part numbers so I could order from amazon or something. Thanks
Old Sep 3, 2013 | 01:15 PM
shipo's Avatar
Every 50,000 miles sounds a bit aggressive; any particular reason for changing those components so often?
FWIW, I'm inclined to use either OEM parts or high-end after market parts from a source like Napa.
Old Sep 3, 2013 | 01:18 PM
JOE.G's Avatar
It's easier for me to order from amazon. I have had problems with plug's seizeing in aluminum heads before so I like to change them sooner then needed. 50,000 miles is a few years for me so it is no big deal.
Old Sep 3, 2013 | 01:48 PM
shipo's Avatar
Plugs I kind of understand (sort of), but wires, cap and rotor every 50,000 miles?
Regarding your plugs, NGK is a good bet.
Old Sep 3, 2013 | 02:09 PM
JOE.G's Avatar
Stock Platinum or Iridium?
Old Sep 3, 2013 | 02:28 PM
shipo's Avatar
I would opt for the exact plug specified by Honda; check your Owner's Manual. As a general rule, the plug recommended by the folks that designed the engine will always out perform any other plug regardless of the exotic metals or the boutique nature of the (plug) manufacturer.
Old Sep 3, 2013 | 08:06 PM
Probably platinum is the stock plug, so that's what I would get.
Honda factory plug wires seem to last forever, so I probably wouldn't change them so often. I would take off the cap & rotor whenever I change plugs, & look to see if they need to be replaced.
It's beyond what you actually asked, but many people forget about changing anti-freeze & brake fluid.
Old Sep 3, 2013 | 09:00 PM
JOE.G's Avatar
I flush The coolant and the Brake fluid on a Regular basis, I am very much on top of Maint stuff.
Old Sep 3, 2013 | 10:59 PM
If you have a Honda cap and rotor in there, leave them. They last a long time. The OEM plug for your car is a NGK Platinum PZFR5F-11. Just follow the maintenance schedule for them in your owners manual. I believe it is every 105K miles. Just use antiseize on the threads when you install plugs. If you are worried, just remove the plugs at 50K miles and put on new anti-seize.
KD1977
Feb 27, 2012 05:58 PM
98accordman
Oct 24, 2010 10:34 PM
Gne3DO
Sep 25, 2010 08:06 PM
mamtsberg
Mar 31, 2008 03:22 PM
accord4sroy
Sep 29, 2006 01:36 PM
