02 sensor questions on 2000 EX V6
Old Oct 14, 2011 | 01:05 AM
RS250 Chester's Avatar
Default 02 sensor questions on 2000 EX V6
Replacing the original oxygen sensors on a 2000 EX V6 model. I don't work on my wife's car that often, so I'm not as familiar with part locations, as compared to my Nissan.
First Question:
There are only 2 02 sensors? The downstream one on/before the cat and the upstream one at the Y collector of the exhaust manifold.
Second Question:
Been searching and kind of confused about the sensors. I've read some posts that say there are "California" sensors, is that the case. I do live in Cali and have a California model. Do I need specific sensors or can I just go to Rock Auto and buy a Denso like I did for my Nissan?
Third Question:
Is the upstream sensor on the V6 easily accessible from the hood. For the life of me, I still can't seem to see it from the hood, if I am looking from the drivers side. I've searched, but I can't seem to find too much info on the V6 sensor location. I have this picture that I found, I assume its correct. Based on that it seems that its easier to get to from the bottom, as I swear I can't find it from the top.
Thanks in advance.
Old Oct 14, 2011 | 09:17 AM
1. There are only 2 oxygen sensors. Primary on the Y collector and secondary on the cat.
2. I believe for the 2000-2002 Accord V6 there is no differentiation between the California and non-California models for the respective O2 sensors. The 1998-1999 Accord V6 for California models used a different secondary (rear) oxygen sensor than the non-California models. (The 1998-1999 Acccord V6 California models also used a different cat then non-Calif. models.)
You can buy from different vendors. Denso primary for 2000 Accord V6 is 36531-P8C-A11 or 36531-P8C-A21(newer). Denso secondary for 2000 V6 is 36531-P8C-L21.
3. Probably easier to access the primary O2 sensor from the bottom of the car.
Attached Thumbnails 02 sensor questions on 2000 EX V6-2000-v6-o2-locations.jpg
Old Oct 14, 2011 | 11:17 PM
thank you for the info, that helps a lot.
pondrun
Nov 8, 2021 09:40 AM
elessar78
Feb 4, 2010 03:30 PM
dmost30
Sep 8, 2008 12:42 AM
dmost30
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
