03-07 sunroof vs non sunroof body, any differences?
Hi guys,
Any ideas if the roof structure is any different on a sunroof car vs non sunroof car in the 03-07 generation? I am wondering if you can cut the hole and then transfer all parts over from one vehicle to another?
thanks.
thanks.
I am aware of that, but electrical, headliner etc is a non-issue as i would have a donor car with the required parts. I know it would be a good bit of work but my only concern is are the two cars otherwise the same (roof structure), so that if one decided to go to that effort, it is just a matter of swapping the related parts over. If the roof on a hardtop and sunroof car are designed differently, then it is a complete no-go as a roof graft is obviouly out of the question.
No, i don't plan on cutting the roof of the donor car and doing bodywork, that is why i am posing the question. I understand and agree with what you are saying re drains etc not a trivial matter, but that is what i am trying to figure out. Do you know they are different for sure from experience or just assuming that they would be? I do know that with some other cars they can be the same. For example, the roof structure on a 4th gen F-body (camaro/firebird) is the same for hardtop and T-top. so adding T-tops is fairly straight forward.
Looking at the body repair manual, the dimensions of various openings (e.g., windshield, doors, rear glass, etc.) are the same, for respective coupes and sedans. This would seem to indicate the roof outer dimensions are the same if comparing a coupe to a coupe or a sedan to a sedan.
Then looking at the service manual, it would indicate the roof for Accords that came with a moonroof has mounting holes on the roof panel to bolt the moonroof frame on. So, if you were to remove the headliner for an Accord without moonroof, you'll probably find it does not have the necessary mounting holes to bolt on the moonroof frame.
Accords with moonroof has less headroom due to the moonroof, moonroof frame, etc.
There is a lip on the edge of the moonroof opening. Just cutting a hole will leave the edges very flimsy with no lip for rigidity. You would have to add/weld something to strengthen the edge of the opening. I think cutting out the roof at the pillars would be easier. In other words, not doable IMO. You would have to go with some aftermarket sunroof if anything.
cd51994accord
Jan 30, 2014 12:56 PM
hondagal74
Aug 14, 2013 09:05 PM
bwhillzy
Aug 28, 2008 11:48 PM
