03 Accord CLUTCH/PEDAL Engagement ISSUE
Old Jul 4, 2018 | 08:24 AM
Kavon42's Avatar
Exclamation 03 Accord CLUTCH/PEDAL Engagement ISSUE
Recently replace entire Clutch (flywheel,clutch disc, pressure plate and throw-out bearing), Master & Slave cylinder due to low engagement clutch pedal and difficulty shifting between gears.
From neutral or park position vehicle would stall out when initiating engagement of 1st or Reverse. If parked in gear, clutch would engage although still had difficulty between gears (1,2,3,4,5).
After replacement, problem still remains! Any ideas what the issue may be? Any and all help appreciated!
Thank you!
Kavon42
Old Jul 4, 2018 | 04:22 PM
Check whether slave cylinder is fully extending. If not suspect air in the system due to inadequate bleeding.
Old Jul 5, 2018 | 08:51 AM
Kavon42's Avatar
Thank you TexasHonda!
What would be considered fully extended?
Old Jul 5, 2018 | 11:35 AM
I could not find any spec on slave cylinder extension. I would guess 1-1.5 inches. You could bleed the clutch circuit.
Kavon42
Jul 1, 2018 10:12 AM
MGF 1996 Accord
Jul 13, 2015 11:48 AM
416communter
Apr 24, 2014 12:15 PM
uh-60mechanic
Apr 26, 2013 08:09 PM
j894
Apr 18, 2013 05:59 PM
