03 CLUTCH engagement issue
Old Jun 30, 2018 | 09:26 AM
Kavon42's Avatar
Default 03 CLUTCH engagement issue
Recently replaced clutch (flywheel,clutch disk,pressure plate & throw out bearing). After install, clutch pedal would not engage clutch, though it still had pressure. Guessing it might be the master cylinder but I AM NO EXPERT. I do know the Master & Slave cylinder was replaced before purchasing car 2 years ago. Any and all help would be appreciated! Thank you.
Old Jun 30, 2018 | 09:49 AM
Have an assistant push down the clutch pedal while you watch the slave cylinder. See if the slave cylinder is moving the fork for the throw-out bearing coming out of the transmission.
Old Jun 30, 2018 | 11:23 AM
Kavon42's Avatar
Thanks PAhonda, just checked and yes the slave cylinder is moving the fork from the transmission. I would say about 1-2 inches of movement.
Old Jun 30, 2018 | 12:23 PM
1-2 inches is about normal movement, so I wouldn't suspect the clutch hydraulics.
Is the clutch staying constantly engaged, or constantly not engaged?
I hate to say this, but I think you will have to pull the transmission and inspect the clutch installation.
The only 2 items I can think would cause this is not installing the fork/throw-out bearing, or the clutch friction disk was installed facing the wrong direction?
Old Jun 30, 2018 | 12:29 PM
Kavon42's Avatar
Constantly not engaged, and yeah I read something about the disc not being set right. I was hoping it was not that. Disc did not have a flywheel side marking so I tried to put it in the same way the previous clutch disc was facing but I believe they are two separate manufacturers.
Old Jun 30, 2018 | 01:15 PM
I am pretty sure the side of the friction disk, where the springs stick out more, face away from the engine and not towards the engine.
There is a good video by ericthecarguy on replacing a civic clutch on an older civic. A lot of the principals apply to your accord. I think this is a video he has for sale for around $10.
Southmain auto on youtube has clutch replacement videos that would help too.
Old Jul 1, 2018 | 05:29 AM
holmesnmanny's Avatar
what was the issue before replacing the clutch ?
what brand clutch did you use ?
Old Jul 1, 2018 | 09:50 AM
Kavon42's Avatar
Thank you PAhonda, that is exactly how I installed the clutch disc and while installing I used a ACT clutch install video as a walk-through/guide for 2003-2012 Honda Accord. Also a Gary Jorges video that matched my exact video, both on YouTube.
Old Jul 1, 2018 | 10:12 AM
Kavon42's Avatar
Thanks holmesmanny, the issue before replacing the clutch was:
Very difficult engaging first and reverse from stationary position and required more effort to engage 2-5 as well.
New clutch is:
​​​​​​​Precision Performance Stage 2 Clutch.
MGF 1996 Accord
Jul 13, 2015 11:48 AM
416communter
Apr 24, 2014 12:15 PM
j894
Apr 18, 2013 05:59 PM
F23AccordLX
Jan 29, 2007 08:13 PM
2.2ex965spd
Apr 20, 2006 03:28 PM
