03 accord dual zone ac problem
Old Jul 23, 2010 | 01:43 PM
Manda_nicole's Avatar
Default 03 accord dual zone ac problem
I have an 03 Honda Accord a/c blows cold on the passenger side but not on drivers side unless sitting still, blows cold on passenger side whether still or moving. Took it to local mechanic and they changed the compressor for some reason and charged the system, did not change the problem just put a big dent in my pocket....seems there maybe an air diversion problem maybe but both sides will blow hot air if heater is turned on....and the only working while sitting not moving is confusing....any help would be appreciated.
Old Jul 23, 2010 | 02:54 PM
Do both fans in front of the radiator turn on when the car is running and the a/c is turned on?
If you turn on the heat in the car, can you change the temperature for the driver's side?
Old Jul 24, 2010 | 08:44 AM
Both fans come on and I can adjust the drivers side to heat and control temp while passenger is still blowing cold......
Old Jul 24, 2010 | 03:26 PM
EXV6NIGHTHAWK's Avatar
Have you tried this? I don't know if it works or not.
Old Mar 29, 2012 | 04:54 PM
hondaboy's Avatar
hi guys thanks for this piece of advise it worked for me , on my 2005 Honda Accord, one side was blowing hot the other side cold , now both are cold
Arfur
May 3, 2010 04:33 AM
nponer
Jan 6, 2010 03:56 PM
BU50
Sep 24, 2008 09:40 PM
lost_ko
24
Jul 14, 2008 04:17 PM
embpilot
Nov 11, 2007 06:52 PM
