Honda Accord '88 wont start when warm please help!
Old Mar 2, 2012 | 04:48 PM
Jeremy Shaw's Avatar
Question Honda Accord '88 wont start when warm please help!
So i have a old Honda Accord its a 1988 and has been running for EVER with no problems...out of no where it started last summer where it would start just fine when the engine was cold...but after running if you shut it off you whould have to wait like a minute.
Now it has been siting along side our hose under a tarp...if you walk over to it it will start right up no problems! just like a champ!
but after the engine is all warm and you shut it off it will not start and it seams you have to wait till its back to a sitting temp.
And if you try to start it while its warm it makes a *click* noise...and the battery is working and everything.
any advice would totally rock!
Thanks In advance!
Old Mar 2, 2012 | 05:21 PM
I like this gen Accord
Do you have a volt meter? When this happens, check the voltage at the starter. Big cable should be ~12.5v. The small wire should read ~12v when the key is turned to start....let us know what you find and we can go from there.
EDIT: I moved this to Gen Tech.
Old Mar 5, 2012 | 05:00 PM
Ok so I just checked it it was at 8v for the small cable and 8.5v for the larger cable.
Thank you for your help thus far.
Old Mar 5, 2012 | 05:10 PM
With only ~8v on both, either the battery or the cables are in need to attention.
Pull the battery and take it to a parts store where they can test it. Before re-installing it, be sure to clean the ends of the cables, not just the ends on the battery but the other end(s) as well.
Old Mar 12, 2012 | 08:13 PM
Ok so now that youve made us all feel like retards...the battery had a bad cell that was causing not to operate when it got warm.
So we replaced the battery and it runs like a champ.
But i have one more question...Our honda has just started revving...like at a red light it was automatically rev...any ideas?
PS. thanks a ton for your help!!!!!
Old Mar 12, 2012 | 10:08 PM
Hey, that was NOT what I was trying to do...
Is the battery light on? Either way be sure the alt is putting out the correct voltage-do you have a volt meter? Are the cables on the battery clean and tight?
Does it do this all the time or just when hot/cold (engine temp)?
I REALLY do like this gen (got three and have had more). I'm in the "grey hair" group that worked/drove these and still do.
Old Mar 28, 2012 | 10:09 PM
Ok so now that may not be a problem....So it seamed like the battery fixed it and it ran great for about a week...not it wont start at all.
its trying to turn over and all and now it wont even start when we jump it or charge the battery...
any idea?
Old Mar 28, 2012 | 10:49 PM
The way the car is not starting will help narrow down the problem.
When you turn the key to start the car, does the starter turn the engine? Or does nothing happen?
Old Mar 29, 2012 | 06:23 PM
And if I can, one or two more details on top of what PA asked.
Auto or manual.
DX, LX or LXi-or another way of getting to what I'm wanting to know, carb or fuel injected.
Also, once again, check the voltage to the starter.
John Gerst
Mar 2, 2013 01:15 PM
bpethomas
Jun 5, 2012 10:47 AM
curtscars
Jan 21, 2012 12:21 PM
effdbmx1
Dec 26, 2009 06:34 PM
tdan04
Aug 26, 2008 06:44 PM
