Hard to start/rough start when warm/hot
Old Jun 3, 2012 | 08:30 PM
bpethomas's Avatar
Default Hard to start/rough start when warm/hot
92 accord 2.2 sedan
After running for a while or driving, when u get out and try to restart it, it takes a while to get it going, u can hear the fuel pumping going and the starter is working. There is no cracks or leaks or issues with the fuel lines.
Any ideas on where to start?
Change the fuel filter?, check the fuel pressure?, check the regulator?
Old Jun 4, 2012 | 06:44 PM
Are you getting spark?
Are there any stored codes?
When was the last tune up (cap, rotor, plugs, inspect the wires)?
Old Jun 5, 2012 | 10:04 AM
bpethomas's Avatar
Yes getting a spark, and last tune up was like 3 weeks ago. We only starting getting this issue when our rad started really leaking and then we replaced it. So since then it has been a problem.
There is no codes either
Old Jun 5, 2012 | 10:47 AM
Dr. Drivability's Avatar
is this the same car you mentioned was blowing blue smoke? if so, i'd check compression. a wore out motor can cause the symptoms you are having.
justmeedp@cox.net
Nov 14, 2013 04:21 PM
KelvinR
May 20, 2013 10:31 PM
rxfields
Feb 8, 2011 10:23 AM
ACCORDingtothestreets
Oct 26, 2009 08:12 PM
raleighfirewall
Mar 16, 2007 08:33 AM
