03 Accord - No Electric Power
Old Jul 11, 2011 | 03:06 PM
frackus's Avatar
Default 03 Accord - No Electric Power
OK, so I think I really messed something up. I was trying to get to a/c compressor so I started to remove alternator. I unplugged the harness on the front, then started to unscrew the bolt holding a connector wire to the alternator...so BIG SPARK when the wrench touched both the alternator bolt and the plenum...(doh! #1) methinks I better disconnect the battery, so I did. Then something came up and I needed to use the car right away so I reconnected the battery, went to start the car but no power....forgot to reconnect the harness (doh! #2). Reconnected the harnes, but no power...no dash lights, nothing. Checked battery fuse and a few others, found nothing blown. Tested battery with meter, seems ok. Yes, I'm a bit of a hack that like to try to fix things but sometimes blows everything up instead. Any help/suggestions are much appreaciated. Thanks!
Old Jul 11, 2011 | 03:17 PM
I would start going through all fuses.
Old Jul 11, 2011 | 03:45 PM
Tek310's Avatar
get the alternator tested. there is a diode in there that protects against reversed polarity.
you most likely blew that, if you are good with alternators, they are easy to rebuild. order the diode and slap that puppy back in there.
Old Jul 11, 2011 | 05:25 PM
You stated you checked the battery fuse; but, also check the main fuse.
Attached Thumbnails 03 Accord - No Electric Power-fuses1.jpg   03 Accord - No Electric Power-fuses.jpg
Old Jul 11, 2011 | 06:15 PM
bootyleggs's Avatar
Redbull-1 helped me with this a few months back( Thanks again). It was the main fuse for me. AAA guy crossed the cables on a jump. Easy fix, and I'm not a car fix it guy so to speak.
Old Jul 12, 2011 | 04:25 PM
frackus's Avatar
Yep, checked it again....it was the main fuse. I missed it the first time...just a tiny hairline break. Needed to put on my 3X reading glasses to see it. Thanks for the help!
1staccord
Mar 25, 2014 06:28 PM
nickvilardi
Aug 15, 2011 12:18 AM
LambertJohn
Sep 17, 2010 01:47 PM
flbob
Sep 15, 2010 03:31 PM
03 Coupe
Feb 22, 2007 06:32 PM
