Sponsored by:
Sponsored by:
03 accord not starting
Old 12-13-2014, 10:17 PM
abrion's Avatar
Default 03 accord not starting
My car sounded like it was trying to start. I know it's not the battery, starter or alternator. I need to know what is going on. please help
Old 12-14-2014, 06:54 AM
Turtlehead's Avatar
Have you checked to see if you have fuel supply to the rail and checked to see if you are getting spark. You need to supply us with more details. Sometimes it is the one little detail that people don't post that is the one that is the tell tail sign of he issue. Is it son auto or a manual. It could be as simple as a park switch or clutch switch is bad.
Old 12-14-2014, 08:44 AM
Confirm engine is turning over fine, but no engine start?
Old 12-16-2014, 02:58 PM
abrion's Avatar
The engine doesnt start. It sounds like its about to start then just dies out
Old 12-16-2014, 03:46 PM
1. Is this a 4 or 6 cylinder?
2. How do you know it is not the battery, starter or alternator?
3. When you try to start the car, does the immobilizer indicator light come on for a few seconds then go out or does it keep blinking?
Old 12-16-2014, 06:34 PM
Turtlehead's Avatar
Ok. You really need to supply more info, otherwise if you want to throw parts at it then I would recommend the ignitor be replaced and the PGMFI relay be replaced as well. I am not being rude but as a mechanic it is impossible to diagnosis the issue given the information. It could also be a bad ignition switch or any number of things. I am relatively new to this site but I have found that the amount of people here that want to help out others is great. Bottom line is there are many knowledgable people on this forum and someone might be able to help you. Please provide more details.
LaGirl
04-24-2012 05:29 PM
misterix
02-05-2009 01:55 PM
cato2008
08-24-2008 05:41 PM
MasterFlex
08-08-2007 01:03 PM
thatboyjer
05-21-2007 11:32 PM
Quick Reply: 03 accord not starting
