03 Accord Thermostat??
Old Jul 21, 2014 | 08:02 AM
black_rainbow's Avatar
Default 03 Accord Thermostat??
Hi All,
I have a 03 Accord and this summer I have been noticing the temp hand rising over half almost to 3/4 when idling, this might be at a drive thru or red light. As soon as I start moving again the hand returns to normal operating temp.
This only occurs when it is very hot outside (28+ C) , fan cuts in but the temp hand still rises.
Also noticed last winter that if I start the car in the morning and leave running for 15-20 mins to warm up. There is no heat until I drive for 2-3 mins and then the air turns hot. The temp hand is in the same position and the car is left going long enough to generate heat.
Could this be the thermostat? Water pump?
All fluid levels are fine.
Thanks for your help.
Old Jul 21, 2014 | 06:38 PM
Are both fans running when it starts to overheat?
T-stats are pretty cheap - even if you go OE which I would. So confirm both fans are working....then go for a t-stat replacement, Let us know what you have from there.
Old Jul 22, 2014 | 04:18 PM
Hi,
When I first checked, both fans were working, however looks like there was a loose connection or short in the fan on the drivers side. Fixed now and the problem is no more.
Old Jul 25, 2014 | 07:36 AM
Thanks for the follow up.
Glad it was a pretty simple repair.
honda285
Dec 16, 2008 07:28 PM
lashlecf
Jun 2, 2008 11:41 AM
cbrf4i1
Jan 6, 2008 05:08 PM
nukem384
Dec 11, 2006 08:09 PM
bwaymire
May 26, 2006 02:04 AM
