03 door lock problem
Old Nov 3, 2007 | 11:02 AM
davethesuave
Default 03 door lock problem
door lock buttons have stopped working; remote will Unlock the doors, BUT will not Lock the doors; interior fuse#8 {20Amp} is good.
any one know what causes this?
PS, we recently had radio code problems, and disconnected the battery several times, but that was maybe a month ago, and this problem only cropped up in the past week.
Thanks in advance.
Old Nov 3, 2007 | 12:14 PM
nafango2's Avatar
Default RE: 03 door lock problem
could be a relay problem, or a problem with the door lock control unit.
Its most likely a relay. when you lock/unlock the doors do you hear a click coming from the front middle of the drivers door?
Old Dec 10, 2007 | 11:12 AM
gte843k
My girl friend's car is having similar problems: (2003 Honda accord Coupe)
Driver's side door will not lock or unlock with the FOB or the inside door opening button. The passenger side locks and unlocks with the inside door lock and unlock button only when the driver's side lock (**** next to windos) is manually pressed down. When that **** is up(unlocked) neither the FOB or the inside the door lock and unlock button will open the passenger lock.
The fuse is fine and others on this forum think it might be the door lock actuator. How do I check the relay or the door lock control unit? I'm trying to diagnose the problem so I don't go out and spend a lot of money replacing the wrong part. Thanks.
Old Mar 21, 2012 | 06:55 PM
Koloheboy's Avatar
I recently encountered a permanent problem with the passenger side door lock/unlock actuator unit on my 2003 Accord. Is this a common problem? Could this be a wear on the cam part of the actuator. I can hear faint clicking. I'll pull the door panel off and troubleshoot.
Old Mar 23, 2012 | 09:12 AM
jcoppeng's Avatar
I am having problems with my door locks on 03 accord lx. The locks will only work if the car us started and the doors are shut. Also, the cruise and radio are not working. Is this all related?
Old Mar 23, 2012 | 10:21 AM
kyle102565's Avatar
take it to dealer.
likely a body control module issue.
stay away
pmay805
Mar 16, 2015 10:41 AM
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
bczupryna
Feb 11, 2006 05:50 AM
