04 accord ex 4 cylinder question
Old Jun 8, 2012 | 06:35 PM
Ryan1984's Avatar
Default 04 accord ex 4 cylinder question
just wondering if it is possible to access the transmission filter on this model and year and if anyone knows where it is located if possible thank you for your time
Old Jun 8, 2012 | 06:41 PM
I checked hydraulic flow schematic of 2003-2007 Accord 4-cyl. shop manual and found no filter anywhere.
Old Jun 8, 2012 | 06:46 PM
Ryan1984's Avatar
ok i will install a magnefine filter instead of getting the current one torn out of transmission thank you tex
Old Jun 8, 2012 | 06:47 PM
The in-line filter is on top of the transmission. Honda does not consider this to be a normal service item. However, many DIYer's do change it.
Honda part number: 25430-PLR-003
See links for picture of location.
Drive Accord Honda Forums - View Single Post - DIY ATF Drain and Fill
Old Jun 8, 2012 | 06:52 PM
Ryan1984's Avatar
so i could remove those hose clamps and connect the magnefine filter directly over passing the stock one if i cant remove it?
Old Jun 8, 2012 | 07:08 PM
Removing the one bolt for the bracket holding the OEM filter is not the hard part, it's more difficult to remove the spring clamps. But right tools makes all the difference.
I have no real knowledge of the Magnefine filters. They supposedly are longer than the OEM filter.
You can refer to this thread for replacing the OEM with a Magnefine.
4 cylinder auto tranny filter (pics) - Drive Accord Honda Forums
Old Jun 8, 2012 | 07:13 PM
Ryan1984's Avatar
yeah if its longer it shouldnt matter and i will just have my mechanic do it rather than swearing at the car
Old Jun 9, 2012 | 09:46 AM
Dr. Drivability's Avatar
hot damn! gonna pick one up and install next week...needs a service anyway, will report back with any shifting quality changes.
Old Jun 11, 2012 | 05:59 PM
Ryan1984's Avatar
yeah you should drain tranny fluid out and refil then drive for 75 miles repeat 3 times
Old Jun 11, 2012 | 06:10 PM
I think Dr. D is a tech from some of his previous posts and info.
blur01
Apr 11, 2016 12:25 PM
Chris Jameson
Feb 19, 2013 06:39 AM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
parallax
Jun 26, 2007 11:22 AM
