04 accord keyfobs stopped working
Old Jul 9, 2019 | 11:04 PM
Bud McGregor's Avatar
Default 04 accord keyfobs stopped working
Both of my keyfobs quit locking and unlocking both doors and trunk. I tried to reprogram the keys with no joy and then I tried to disconnect the battery and jumper the hot and ground leads together to reset the MCU. Still no good. Any other things that this amateur can check before I ask the Honda dealer how big a mortgage I need to apply for? The door locks still work from the armrests. (I just replaced the drivers side lock actuator.)
Old Jul 24, 2019 | 09:59 PM
It might possibly be due to a faulty driver's door multiplex control unit (MCU).
The antennae is part of the driver's door control unit. The door mcu is part of the driver's master window switch.
Old Jul 25, 2019 | 03:37 PM
Thanks for your input. I would never have found that info otherwise. Everything I found on the internet was for other cars and seemed to be both expensive and something of a job. It seems that most mcu's are located in the kick panel behind the fuse block.
Curiously enough, I did just replace the control module in the drivers door. But, unfortunately, the problem started before the change and both modules exhibit the same problem. Perhaps you can tell me whether the MCU, if replaced, needs to be reprogrammed and exactly where it is on an '04 accord.
Again, thanks. I do appreciate your help.
19962door
May 7, 2012 12:43 PM
foxylady23
May 19, 2009 01:13 PM
dbennett3
Aug 11, 2008 11:49 PM
jayallen40
Dec 4, 2005 10:46 PM
88COMMUTER
May 26, 2005 10:03 PM
