04 Accord Sedan Trunk Will Not Open
Old Oct 31, 2016 | 06:01 AM
sawtooth500's Avatar
Default 04 Accord Sedan Trunk Will Not Open
Trunk won't open. I suspect a sticky latch. I put the back seat down, and the metal latch inside the trunk holding it closed does not move. Won't open with the key on the outside of the trunk, the lever on the driver's side, or the release from within the trunk.
Perhaps it just needs to be lubricated? Is there any cheap and easy way to make it work again?
Old Oct 31, 2016 | 09:58 AM
YouTube is a wonderful resource.
Old Oct 31, 2016 | 03:05 PM
Johanson2424's Avatar
might as well try greasing it up before bringing it to any mechanic or dealer. but first things first, do you hear the release sound that normally happens when you go to pop the trunk?
Old Nov 1, 2016 | 10:27 AM
A few weeks ago, I did hear the "click" sound, but the trunk didn't open. I banged on it a few times, and then it opened. This time, I am not hearing any click sound at all, so that's why I suspect that it just needs to be lubed up. Would WD-40 be fine? Any particular place I should spray it? Mind you, this would be done from inside the trunk through the back seat...
Aceimager
Mar 27, 2012 01:09 PM
gobears81
Oct 5, 2011 06:14 AM
Accord16_Al
Jun 11, 2011 05:54 PM
accordfan
Aug 9, 2010 09:09 PM
