04 coupe power steering pump
Old Mar 8, 2011 | 03:10 PM
pavman65's Avatar
Default 04 coupe power steering pump
Need help with 04 coupe power steering problem. Seems to be getting air in the system. The fluid turns brown with air bubbles in it building up pressure and forcing fluid out the cap. Eventually causing the fluid to run low and the
pump to start squealing. Always adding fluid and making a mess. Please help.
Thanks, Pete.
Old Mar 8, 2011 | 04:49 PM
Check your fluid reservoir. Submerged in the fluid should be a fine mesh screen. If that gets plugged with crud, the pump will have a hard time sucking fluid from the reservoir. Then it can suck air through a leaky hose fitting (rather than leaking OUT).
Old Mar 8, 2011 | 07:17 PM
EXV6NIGHTHAWK's Avatar
Very common problem. The o-ring, on the inlet joint allows air to enter the system. Easy fix, with a 10mm wrench.
Old Mar 9, 2011 | 12:32 PM
pavman65's Avatar
Default Thanks Fellas
I'll give both a try and let you know how it goes. Thanks again for your help.
ken830
Sep 9, 2010 05:10 PM
Rizzie
Aug 21, 2006 03:26 AM
BDN54
Mar 9, 2006 02:34 PM
WS6M21
Dec 4, 2005 11:37 PM
WS6M21
Nov 9, 2005 01:50 AM
